Keep away from open flame.
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
daren-schwenkeDaren Schwenke 09/06/2018 at 22:570 Comments
I was mounting the head and putting on a bit of heat-shrink when I got too close to one of the lines.  Oops.
So much for seeing if it would stay calibrated when I moved it to the Makerspace tonight.
A little bit of code, an hour drive, and now replacing a line are what stand between me and a video for you all.
EDIT: Ok.. a little more than a little bit of code.  My digital pins within Machinekit are not cooperating, so I can't control the mirror or light from within Openpnp.  Ah well.
Recorded where I'm at anyway.
