Burn baby burn.
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
daren-schwenkeDaren Schwenke 09/16/2018 at 19:000 Comments
Noticed as I was assembling the new main light ring in ABS that the edge had lifted and it was a little warped, and the 0.3mm single wall print was a little too thin for my comfort.  I changed it to two wall and reprinted.
I also noticed if I run the ABS as the absolute top of its heat range, like 275C, I get a flat black finish instead of more glossy.  Hey... I can use that.
So I reprinted the part light ring like that.  It is there to keep the light from hitting the mirror directly, so a flat finish is good.
