Suspect servo statistics subvert successful spline syncronization
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
daren-schwenkeDaren Schwenke 02/11/2018 at 00:360 Comments
Everything fit, but my gears for nozzle rotation didn't mesh properly.
To line things up and make the cutouts for where the servos were going to sit I had two different models.  One was the actual servo model, and one was the negative I used to generate the pocket it would need.  The negative one was a little oversized with exaggerated depth for the flanges and pegs to generate the screw holes.  It worked well.
Well it seems over the course of the project I accidentally modified the cutout version and changed the depth from the output shaft to the mounting flanges.  I've flipped the side of the flange I was going to use a couple times so I can understand how it happened..
Blue is the original, yellow is my cutout.
Depth is kinda important for a right angle drive, so now the gears don't mesh.  Fixing.
