Accuracy.
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
daren-schwenkeDaren Schwenke 02/16/2018 at 23:180 Comments
The mirror arm has to stop at exactly the same angle/place every time for this idea to work.
I've tried to plan for this:
This seems to have worked.  For the video I was swinging the arm itself by hand from one side and driving the servo unpowered in the process to a random angle.  If you look carefully at the video, I was still looking right down the bore of my 2mmx50mm shaft straight enough nearly every time to see the circle of light from the other end.
EDIT: I noticed the circle of light wasn't quite a circle.  Turns out I still had flashing from cutting the tubing on the end inside the brass bit.  Now.. it's a circle...  :)
