FluidicPC
Experiments with creating air flow digital counting machine
Experiments with Coanda effect devices
Each part should be 3D printer and assembled to counting device
Links:
From Scientific American, December 1964, pages 80-88:
http://miriam-english.org/files/fluidics/FluidControlDevices.html
Coding and Computation in Microfluidics(coanda-less pneumonic devices ):
http://cba.mit.edu/events/07.05.fluid/
Exploring macro scale fluidic logic systems in LGA:
https://courses.cs.washington.edu/courses/cse599d/13au/projects/AaronParks/macro.htm
Aerodinamics effecrts in pneumonic:
Adobe Portable Document Format - 27.24 MB - 02/01/2018 at 05:35
Preview
Download
View all 4 project logs
  • 1
    Step 1: Reproduce "Volga" logical elements
    Using album of USSR "Volga" fluidic elements we need to redraw it, model in 3D, model LGA simulation and create prototypes.
    Each element would have 50x30x5mm or something like this and represent one elementary logic operation
  • 2
    Step 2: binary neuron experiments
    Let's take one XOR element, two RS-triggers and two 2AND elements and combine them into elementary binary neuron with two (or more) inputs. Each input have only two states - On and Off, and weights can be 1 and 0. So we send input to XOR element or not.
    Current weight states are stored in RS-triggers, so we can program them before use.
  • 3
    Step 3: Fluidic neurons prototypes
    We put neuron schematic into one logic element, let's name this element of Neva series.
    As fluidic elements by themselves are small (10x10mm) and only air tracts are take most part of chip space we can put or five elements into the module with the same size as Volga elements.
View all 6 instructions
[deleted]
Artem Kashkanov wrote 04/06/2020 at 08:55 point
I'm note sure that I want to explore microwave devices :)
Yann Guidon / YGDES wrote 04/06/2020 at 10:39 point
Ooops !
It was a mistake, sorry, I erase it :-)
Artem Kashkanov wrote 04/06/2020 at 08:58 point
As for microfluidics this is very interesting tools, but harder to replay that "big" fluidics.
I found some methods how to do microfluidic elements - e.g. this one https://www.youtube.com/watch?v=eNBg_1GPuH0
Look like easy to try.
Sbitardov wrote 02/03/2018 at 15:54 point
Hi Artem, do you know there are dozens of Soviet books about fluidics? It is called пневмоника, but that`s the same thing.
See e.g. here:
http://publ.lib.ru/ARCHIVES/B/''Biblioteka_po_avtomatike''/_''Biblioteka_po_avtomatike''_0400-0499_.html (books No 457, 478 and more, switch pages at the top)
http://retrolib.narod.ru/books14/1965_salmanson.djvu
https://www.twirpx.com/file/1603666/
http://lab18.ipu.ru/projects/conf2013/1/2.htm
http://publ.lib.ru/ARCHIVES/G/GERC_Elena_Vasil'evna/Pnevmaticheskie_ustroystva_i_sistemy_v_mashinostroenii.[djv-fax].zip
Artem Kashkanov wrote 02/23/2018 at 09:37 point
Hi, Cool books list. Thanks! Yes, I already have some books in this list.
Yann Guidon / YGDES wrote 02/01/2018 at 12:38 point
Why is the project private ?
Artem Kashkanov wrote 02/01/2018 at 12:54 point
Just because of draft status)
Yann Guidon / YGDES wrote 02/01/2018 at 11:51 point
Oh my.
If you throw LGA simulations in the project, there is NO WAY I could refuse your invitation !
Artem Kashkanov wrote 02/01/2018 at 11:56 point
Assume LGA(or other) simulation is only one way to get a guarantee that this will work
You know I'm a LGA fanatic ? :P
Artem Kashkanov wrote 02/01/2018 at 13:13 point
From this moment I know :) As for me I never used LGA before
