1 bit full adder on fluidic elements
09/15/2022 at 13:16 • 0 commentsI assembled fully-functional 1bit full adder on 10 fluidic elements. Which doesn't require electricity for work
Fluidic-based elements can be bigger that they should be
09/04/2022 at 14:28 • 0 commentsV - means VISIBILITY. Fluidic-based element is good for scaling to both sides.
Fluidic element opensource CFD simulation
07/18/2022 at 05:42 • 0 commentsI made a setup of openfoam + CFDof + freeCAD with fluidic element and could start CFD simulation of what's happening inside and why element works incorrectly in reality. THis design was bottowed from VOLGA elements datasheet.
First 3D-printed fluidic logic element
07/04/2021 at 21:03 • 0 commentsThis is the first 3D-printed 2NOR Logic gate that works on the Coanda effect - the tendency of a fluid jet to stay attached to a convex surface.
Fluidic element prototype
01/18/2019 at 08:27 • 0 commentsMy friend Anton sent me photo of his current early-bird prototype for investigating fluidic elements.
Look brutal but it work. non-stable, but work
Fluidic logic element first simulations
10/23/2018 at 09:25 • 0 commentsBase logic element simulation results for setting to log.1 right control channel:
And left control channel:
Fluidic Logic USSR elements "Volga"
02/23/2018 at 09:59 • 0 commentsSbitardov in his comment gave me cool book that I never see before.
It's about ussr logic elements named "Volga". Quality of album is enough to reproduce the same modules with 3D printer. Let's take a loot of some elements:
OR gate with 2 positive and one negative input.
Trigger. Main differnece that it have symmetric camera. As a result - it's bistable.
AND element. 5 = (2 && 3) && !6
Other elements are here: https://www.twirpx.com/file/1603666/
This file is too large to add it here.
Fluidic kit
02/02/2018 at 09:06 • 0 commentsCuriosity led me to the Internet archive, so I found interesting kit pictures from Tekniska museet
Assume there are different logic elements in it and some additional devices for making experimentsI can't find it on ebay, but it looks so cool, so I want to find it out.I'm not sure that this is coanda effect logic. Or logic in general, but..
Links:
https://archive.org/details/arkivkopia.se-digmus-tek-TEKA0008814
https://archive.org/details/arkivkopia.se-digmus-tek-TEKA0008813
https://archive.org/details/arkivkopia.se-digmus-tek-TEKA0008820
https://archive.org/details/arkivkopia.se-digmus-tek-TEKA0008816
