FitBit API Part 1: Getting the data
A project log for Sci-fi grade Home Automation
A system that ties some home automation with various APIs and hardware hacks.
conradcnconradcn 03/15/2014 at 03:450 Comments
FitBit wouldn't let me use their API officially without a significant amount more effort than I was willing to put into this project (They wanted a website, among other things. Psh.), so I loaded up my trusty Fiddler and opened a session to their site. The dashboard program gets data with two basic calls:
A post to http://www.fitbit.com/login with my account credentials
A post to https://www.fitbit.com/ajaxapi with any API calls I want to make (using the cookies from the first session)
The ajax API just takes in JSON strings as input and returns the requested JSON as output. With a little experimentation, I found the format to be the following:
The request I was interested in (sleep data) is a URL-encoded JSON string with the following structure
request={"template":"/mgmt/ajaxTemplate.jsp","serviceCalls":[{"name":"activityTileData","args":{"dateFrom":"2014-03-13","dateTo":"2014-03-13"},"method":"getSleepTileData"}]}
Part 2 will cover converting the data to a usable dashboard.
