ESP8266 Wifi Smart Garage Door
Use an ESP-01 micro controller to control your Garage Door
The ESP8266 System on a Chip (SOC) is a very inexpensive way to make your thing internet connected. Let's explore using the ESP-01 version of this SOC to make our garage door smart.
This is a follow-up project to my more expensive smart garage door opener at http://hackaday.io/project/4027-arduino-openhab-garage-door-control
This project uses an ESP-01 SOC programmed with NodeMCU.
This project uses the ESP-01 to control the garage door opener as well as sense when the door is open or closed.
The ESP-01 talks via wifi to an OpenHAB controller that monitors door status as well as sends door open/close commands.
  • Prototype Complete!
    Pete Hoffswell03/09/2015 at 02:16 0 comments
    The controller has been installed and running great for a few days now. Stability looks to be very good. If I can get my hands on a 3.3v relay and a strong 3.3v power supply, this could move from the bread board to a perf-board.
View project log
  • 1
    Step 1
    Wire the ESP-01 as follows. Go ahead and leave your TTL converter connected so you can continue programming and debug.
  • 2
    Step 2
    Connect your ESP-01 to your TTL serial converter and flash your ESP-01 with NodeMCU
    Follow Marc's good instruction on how to load NodeMCU onto your ESP-01 at https://importhack.wordpress.com/2014/11/22/how-to-use-ep8266-esp-01-as-a-sensor-web-client/
    ESPlorer is a great way to program the ESP-01. Get ESPlorer IDE running, so you can access and program the ESP-01.
    http://esp8266.ru/esplorer/
  • 3
    Step 3
    Program your ESP with the following code -
    Change the ip address of the M:connect command to match the ip address of your MQTT broker.
    -- Garage Door controller version 2/15/15 pete@hoffswell.com
    -- GPIO0 is connected to switch with internal pulldown enabled
    gpio.write(3,gpio.LOW)
    gpio.mode(3,gpio.INPUT,gpio.PULLDOWN)
    --GPIO2 is connected to Relay
    gpio.mode(4,gpio.OUTPUT)
    gpio.write(4,gpio.HIGH)
    print("Program Start")
    -- Start up mqtt
    m = mqtt.Client("ESP1", 120, "user", "password")
    m:lwt("/lwt", "offline", 0, 0)
    m:connect("192.168.15.22", 1883, 0, function(conn) print("mqtt connected")
       m:subscribe("openhab/garage/relay1",0, function(conn) print("subscribed relay1")
       end)
    end)
    -- Reconnect to mqtt server if needed
    m:on("offline", function(con) print ("reconnecting...")
       tmr.alarm(1, 10000, 0, function()
             end)
          end)
       end)
    end)
     -- Switch Trigger
    gpio.trig(3, "both",function (level)
       state = gpio.read(3)
       m:publish("openhab/garage/switch1",state,0,0)
       print("Sent openhab/garage/switch1 " .. state )
    end)
    -- MQTT Message Processor
    m:on("message", function(conn, topic, msg)
       print("Recieved:" .. topic .. ":" .. msg)
       if (msg=="GO") then  -- Activate Door Button
          --print("Activating Door")
          gpio.write(4,gpio.LOW)
          tmr.delay(1000000) -- wait 1 second
       else
          print("Invalid - Ignoring")
       end
    end)
View all 5 instructions
dbagioniff wrote 02/25/2017 at 02:42 point
Any help with the MQTT set up.  I keep hitting a wall with it HARD.  I can get it running on my server but cant seem to get it to do much else.  Need advice.
Dave wrote 11/15/2016 at 13:17 point
questions.....there is a resistor soldered onto the 8266 board, what is its value and purpose. Im setting up to try an build this myself.
Pete Hoffswell wrote 07/27/2016 at 12:09 point
Hi Dwayne -
The contact switch that senses the door open/closed state simply completes the circuit.  You can install it either way.
For the init.la file, you might need to put in a delay?
Dwayne wrote 07/27/2016 at 19:05 point
I got the switch working properly now. i didn't know the resistor were needed to be left in circuit. works like a charm now. this is awesome, and will be adapting to make this run my electric gates. Thank you very much (although i found one that you wire into the remote control for the gates, but cant seem to find it now)
how would i add a delay?
i believe its the esp01 version that i have (black 1mb version) and the way (Settings) i am flashing the nodemcu firmware. since the tutorials are a little outdated (now you must build your own custom firmware) and mostly are for the 512kb version, i think i am doing something wrong.
in ESPlorer it gives me the cant detect firmware version, and then once i reload it once or twice i am able to manually start the init.lua file. ive posted in the esp8266 forum, and there does not seem to be alot of movement.
Dwayne wrote 07/27/2016 at 00:54 point
I have a question on how to wire the sensor. One side goes to positive or negative?
Also I got this working wonderfully when I start the program thru esplorer. But init.la does not load by itself
