So, here's some updated setting I have been using to get better resolution from chilipeppr.... ( this is with my 1watt laser, so the cut speed is pretty high )
Inflate Milling Path By: positive +0.05 negative -0.05 Advanced Inflating Inflate SMDs By positive checked -0.1 negative checked -0.1 Clip wires unchecked Remove Undefined SMDs unchecked Inflate Pads By checked -0.1 Inflate Vias By unchecked 0 Depth of Milling Traces 0 Feedrate for Milling Traces 400 Feedrate for Plunge into Copper 800 Clearance for Z Axis Moves 0 Depth of Cutting Out Dimensions 0 Step Down for Cutting Dimensions 0 Feedrate for Cutting Dimensions 400
And here's slightly upgraded python script that lets you use the input and output names as command line arguments.. Pretty basic still...and it still keys off the cut speed, so I need to find a better way...just haven't spent the time yet...
import os
import sys
total = len(sys.argv)
cmdargs = str(sys.argv)
inputFile = sys.argv[1]
outputFile = sys.argv[2]
if os.path.exists(outputFile):
os.remove (outputFile)
outFile = open(outputFile, 'a')
with open(inputFile) as f:
for line in f:
if line.startswith( 'F400' ):
outFile.write("M3" + chr(13) + chr(10))
print ('M3')
if line.find( 'G0' ) != -1:
outFile.write("M5" + chr(13) + chr(10))
print ('M5')
outFile.write(line)
print (line)
outFile.close()
fl@C@
