Some useful comments
A project log for ESP8266 Interrupt Driven Meter Monitor
A network node that will sit in my meter box and read meter pulses. The node will store accumulated readings based on pulses/min.
stuart gogginstuart goggin 03/10/2015 at 13:190 Comments
Monitoring TCP traffic on a Ubuntu box
http://manpages.ubuntu.com/manpages/utopic/man1/nc_openbsd.1.html
nc -l -p 888
The Hardware
ESP8266 as the main controller
LM393 light sensor such as this one:
Image result for lm 393 light sensor
Desolder the sensor and remote mount it. It's just a cheap LDR. Plan is to stick it onto the LED on the meter.
Powersupply - Breadboard 3.3v 5v supply
Software Overview
Pulse Detect line to ESP8266 - I'm using GPIO in my sample circuit - but have to switch to GPIO 2 as it makes reprogramming tricky.
ESP8266 Interrrupt to pick up changes in light levels. Due to noise - need to decouple the ISR. So plan is to use a software debounce approach. A standard ISR will count the pulses - which might be several thousand per pulse. A second timer will operate every 10msec, and if the count of ISR pulses is > 1 then increment a second counter by 1. This will ensure that the circuit does not pick up noise.
The software will record pulses per minute. A minute timer will kick off and reset the pulse count. It will then open a TCPIP connection to
The data will be written to a ESP File and stored for later retrieval as required.
