Rethinking the mechanical part
A project log for 3D Printed Parametric Motor
Custom electromechanical motor that can be printed using any 3D printer, some coil, maybe magnets and a controller.
solenoidSolenoid 06/21/2015 at 04:062 Comments
I spent some time thinking how to make the building process as easy as possible, after all the motor needs to be printed, colied, assembled, mounted and controlled. The first concept wasn't very user friendly in that sense.
Fig. 1: New concept. Looks like a standard stepper motor.
Fig. 2: Exploded view of all the parts.Fig. 3: Rotor.
This second concept is all about using off-the-shelf parts. It's controlled like a 2-phase stepper motor when the rotor has magnets on it (synchronous) and when coils are put on the rotor it works as an asynchronous motor.
This makes it easier to control, stepper controllers are really cheap these days and I happen to have some at hand so I won't have to build custom electronics.
For the rotor it's probably better to use something sturdier than a printed axle, a metal rod will do. I decided to use the tiny 635 type ball bearings on either side of the rotor as well. The motor can still be made with only printed parts though.
This is still a concept, I haven't printed anything yet because I don't have access to my printer currently.
xobmo wrote 06/24/2015 at 00:18 point
Love the new design.  Do you have the cad files?  I'd like to try and cut them into 2.5D for those of us with a CNC but no printer.
Solenoid wrote 06/24/2015 at 05:10 point
Sure, here you go (Google SketchUp file): https://www.dropbox.com/s/abqmtls4qyvz9tp/Square.skp?dl=0
The rotor is just a place holder for now. I'm thinking that the first concept was too ambitious (with the 100% custom motor design) to be feasible in one shot. I think I'll dial it down with more restrictions, I'm thinking about using the NEMA standard sizes and only allow few custom parameters for the first version.
