Op Amp Section Works!
A project log for +/- 10V to 0-3.3V Translator
Differential Op-Amp Circuit to translate +/-10V DAC signals from test equipment to 0-3.3V for Teensy 3.6 Board
emach00Emach00 06/25/2018 at 15:590 Comments
Finally got around to testing the op-amp section of the circuit. It works as advertised. The linearity is pretty good. :)
Still need to get around to putting this onto protoboard and into a project box.
