The Mother of All Print Cooling Fans
Remote print cooling using a centrifugal air pump from a CPAP machine.
This is a remote (as in not mounted on the extruder carriage) print cooling blower that uses a centrifugal air pump and hose from a CPAP machine to deliver air to a nozzle that surrounds the extruder nozzle in a 3D printer.
Some people use aquarium pumps to make remote print cooling blowers for their 3D printers.  It's hard to get enough air to the print that way, unless you get a big pump, but that gets expensive and noisy.  I wanted a way to deliver a variable and copious amount of air that would be quiet, relatively low cost, and could be driven by the normal PWM print cooling fan output from a 3D printer's controller board.
CPAP machines uses centrifugal air pumps with very high quality, long-life, brushless DC motors that can move a LOT of air very quietly.  About two years ago I picked up such a blower at my local American Science and Surplus store in Milwaukee for $8.  The trick was figuring out how to power/drive it.  A few RC hobbyists at the makerspace told me to get an ESC and servo tester for a model airplane and I should be able to drive that blower, so I ordered parts from HobbyKing ($10 and $5) and it worked well:
Blower test video from Mark Rehorst on Vimeo.
That particular blower obviously moved far more air than needed.  The only problem was the ESC and servo tester didn't have an easy to tap PWM input and would not just start up the blower when powered up (safety- you don't want your helicopter blade to chop up your hands as soon as you connect the battery!).
It all sat for a while until someone left a CPAP machine on the hack-rack at the makerspace.  It had a slightly smaller blower, so I decided to try looking for drivers again, and found the perfect driver on ebay for $13 shipped from Hong Kong.  It's rated for up to 36V, 350W, so it would operate from the 12V switched fan output on my SmoothieBoard controller.
If you want to try something like this, it isn't usually too hard to find a CPAP machine at a garage sale or by asking a relative.  People often stop using their CPAP machines because they can't adjust to sleeping with the mask that goes with them.  You won't find them on ebay or Craig's List because they are medical devices, but you can get the hoses there.
You can get similar blowers from Chinese suppliers via ali-baba for about $25.
This one even comes with a driver for $35.
Details of the whole thing are on my blog.  TLDR: I printed a nozzle for UMMD's extruder carriage, clamped the blower to the printer and ran the air hose along the drag chain that brings the cables to the extruder.  The driver has a PWM input but I just connected the driver's power input to the MOSFET that normally drives the print cooling fan.  It works well and is capable of delivering at least 10x the airflow needed.
First test print with CPAP blower for print cooling from Mark Rehorst on Vimeo.
First test print with CPAP blower for print cooling, continued. from Mark Rehorst on Vimeo.
I know the print is excessively hairy- I'm still struggling to tune up the extrusion parameters for the 0.8 mm nozzle on the volcano heater block.
I haven't decided if it is going to be a permanent addition to the printer yet.  I'm in the process of redesigning the extruder carriage and may add this as a permanent part of the design.
I see two primary advantages to this type of set-up.  First, you're guaranteed to have more than enough air flow available, and second, it requires less lateral space on the extruder carriage compared to squirrel cage blowers and ducts/nozzles mounted on the extruder carriage.  The space issue can be a big benefit because it allows for serious print cooling without reducing the lateral build dimensions of your printer as much as hanging a blower from it might.  Neither of the print cooler design is particularly optimized yet, but the remote type is already smaller on the first pass.
Centrifugal air pump from a CPAP machine.
JPEG Image - 244.34 kB - 02/01/2018 at 19:30
Preview
Download
  • 1 × BLDC motor driver: https://www.ebay.com/itm/5V-36V-350W-DC-Brushless-Motor-Controller-BLDC-PWM-Driver-Board/391753214067 5-36V 350W brushless DC motor driver with PWM input
  • 1 × CPAP blower: pulled from a DeVilbiss CPAP machine Centrifugal air pump with brushless DC motor
  • Printable Centrifugal Blower
    Mark Rehorst03/22/2020 at 12:57 0 comments
    Shortly after I did this project I got back into it and made a 3D printable blower by copying the design of the CPAP blower in the photos of this project.  I posted the printable blower project to my blog.  That blower uses a motor from a junked hard disk drive, but can easily be adapted to a brushless model airplane motor.
    The recent COVID-19 pandemic has generated a lot of interest in that printable blower for potential use in a DIY/low cost ventilator.  Who would have anticipated that?
View project log
salteood789 wrote 04/01/2023 at 22:01 point
There has been a great deal of value to me in my involvement with the project. Would like to share it with the happy mothers day to pregnant woman team so they can also read it and implement something new.
MastaRob wrote 02/07/2020 at 11:21 point
I added a chunky CPU fan to my 3d printer, and while it works great for overhangs etc I've also been getting some pretty monstrous stringing. I redirected the air flow down a bit so less was on the nozzle, which helped, but still an issue. Wondering if you are experiencing the same, or if you have any thoughts on this?
seilerjacinda925 wrote 11/19/2019 at 15:44 point
Hi
Nice to meet you after viewing your profile i am Jacinda, from (jakarta) indonesia,
i have a project discussion with you please email me on: (jacinda.seiler@yahoo.com)
Mark Rehorst wrote 02/07/2018 at 20:37 point
I'm not sure you could balance a 3D printed part well enough to use it.  The original part has an injection molded impeller that has a couple little rat bites on the edge that were used to balance it.  Even if you could get it balanced, I'm not sure a 3D printed part would hold together if you spun it really fast.  It would be an interesting experiment...
Lee Cook wrote 02/07/2018 at 12:27 point
Could you 3D print the blower, add a couple of bearings and drive it with a cheap hobbyking brushless motor?
