Microwave 3D print repair
The door latch mechanism broke. Drew and printed a replacement, still going strong 4 years later
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
As the title states. If you look at the photo with the black part, on the very right hand side there is a tab broken. Couldn't find a replacement part so had to crack out the calipers and get drawing. Took quite a while to replicate in Autodesk 123 Design. Printed in bog standard PLA with 20% infill and four years on, it's still intact.
