This log is about a particular microkernel approach.
One important result of my explorations is to keep code small and well defined and turn the knob of the GNU HURD all the way up to 11 : "everything is a server". This has been studied with the #YASEP Yet Another Small Embedded Processor and resulted in the creation of the IPC/IPR/IPE trio of opcodes.
Ideally, any program would be split into chunks of about 64KB of instructions. The only way to communicate is to call the IPC instruction (InterProcess Call) with the ID of the called process, and an offset into the code. This call is validated by the IPE (InterProcess Entry) instruction, on the called code, which saves the callee's information in registers so the called code can accept or deny execution of the following code. IPR (InterProcess Return) is called to return to the callee's context.
This is a clear separation between code domains. This should prevent both the Spectre and ROP (Return Oriented Programming) types of attacks. This might look a bit slower than the "direct call" approach (as used in Linux "because it's faaaaast") but when well implemented, it shouldn't be much slower than a CALL within a process. It just exposes the costs of jumping from some code to another, without microcode or stuff like that.
So I advocate the following : split your code into small bits, for security and safety. Make them communicate with each other with protected calls to prevent mischief. This also promotes maintainability, modularity and code reuse, in an age of bloatware and executable programs that weigh many megabugs, I mean, megabytes...
Of course, this requires special instructions and a total rewrite of the operating system. Which means that current applications must be reviewed and there is no direct path to port GNU/Linux stuff. OTOH, the POSIX model offers little intrinsic security...
Another aspect to this is : separate processes with private data spaces need a SAFE, efficient, simple and flexible way to exchange blocks of data. This is a subject for a future log...
Yann Guidon / YGDES
