Input-Output architecture
A project log for PDP - Processor Design Principles
Distilling my experience and wisdom about the architecture, organisation and design choices of my CPUs
yann-guidon-ygdesYann Guidon / YGDES 02/22/2018 at 04:150 Comments
In the wild, you will find two approaches, best illustrated by the Motorola vs Intel debate.
In the 70/80s, separate IO spaces would ease decoding at the cost of more IO pins on the CPU.
In the 90s/2k, well, memory has become black art then PCI arrived so the mess is much worse.
I design a dedicated "space" to separate differing resources because they have different requirements : latency, speed, bandwidth, granularity, protection/safety, ordering, restartability...
I use IN and OUT instructions to access anything that is not related to data storage. This is more or less equivalent to Intel's MSR introduced with the Pentium, 25 years ago. Semaphores, synchronisation, interrupt management, debug, profiling... can only work with word-wide accesses and fine-grained rights. This allows capability-based (or whitelist, or object-based) rights management, for example each peripheral could be accessed only by a given thread ID. Of course this also greatly simplifies the memory system because you don't rely on certain properties, that are relegated to a dedicated channel.
