ECUality1
A light, open-source Engine Control Unit (ECU) using Arduino
This project is about taking full control of a fuel-injection system, and making that process easy to understand and do. Currently, the system is built to run the engine in a 1984 VW vanagon. I aim to create a platform that bears adaptation requiring a minimum of external tools.
ECUality differs from other ECU projects in that I avoid relying on complex tuning software, favoring simple map-tuning algorithms that run all the time.
Current status: Runs engine cleaner and smoother than stock ECU
Firmware Build tools:
  • Visual Studio Community 2013 (free) with Visual Micro.
Interface to the Firmware:
  • The Arduino serial monitor
Engines supported:
  • Now: 1984 VW vanagon gasoline "digijet" (in development)
  • Next: 8-cylinder Vortec engines with tuned-port injection
Control outputs
  • Now: injectors only
  • Next: ignition coils, with or without distributor
Auto-tuning
  • Automatically adjusts engine map (this is unusual among aftermarket ECUs)
  • Now: based on narrow-band O2
  • Now: global and local (on the map) fuel adjustments at fixed change rate
  • Next: Wide-band O2
Injector timing:
  • Batch-fire
  • Next: sequential
ECUality Manifesto v1.doc
An explanation of the design motifs that set ECUality apart
msword - 28.50 kB - 03/22/2016 at 09:56
Download
ECUality1.2.sch
Eagle PCB schematic
sch - 767.69 kB - 03/20/2016 at 05:13
See BOM
Download
ECUality1.2.brd
Eagle PCB layout
brd - 262.99 kB - 03/20/2016 at 05:13
Download
ECU_parts.lbr
Eagle library of special electronic components
lbr - 17.82 kB - 03/20/2016 at 05:11
Download
  • 1 × Arduino Mega 2560
  • 1 × ECUality1.2 bare pcb
  • 1 × MC33810 4x injector driver and 4x ignition coil pre-driver
  • Moving Ignition timing to the ECU
    Mike Thielvoldt18 hours ago 0 comments
    My hall effect signal has been slowly deterioriating.  I am using this as an opportunity to bring the ignition timing under control of the ECU.   In doing this I will be replacing the 1984 distributor, which featured centrifugal and vacuum advance with a 1986 distributor which has neither advance mechanism because these features were moved to the ECU for that model originally.
    Basically, I'm following in VW's 1980's footsteps.  Below is a fun video of me testing that the programmed timing is going to fire when the rotor will be pointing at a plug wire.
  • Parameter Access from Dash Terminal
    Mike Thielvoldt03/16/2016 at 21:05 0 comments
    The Problem: poor parameter access
    I was having this experience where something would be not quite right, but I couldn't do anything about it until I broke out the laptop and plugged into the USB. Most of the time it would be a simple matter like a parameter was a little high or low, but sometimes even the laptop didn't give me enough access to fix those problems.
    An example: When the engine is cold, the mixture is fuel-rich to compensate for the lower available thermal energy for ignition. In the carburetor days, the engine would be said to be "on the choke". Of course, as the engine warms up, the extra enrichment can taper off. The exact shape of this enrichment curve is experimentally determined, since it would be impractical to model all of the contributing factors, but easy to just try numbers and listen.
    And yet, I found it difficult to hook up the laptop and tune by ear. Not only is the laptop clunky and not always present, but I also couldn't send inputs very quickly, because I had to copy and paste a whole new pair of arrays into the terminal window. As the engine warmed up, I would lose my chance to tune.
    The Answer: a button-navigable menu of all parameters
    Having only 20 buttons and about as many parameters, I decided to use two buttons to scroll (up or down) through the list of parameters. The selected parameter can then be increased or decreased by two more buttons, and a final pair of buttons amplifies or diminishes the effect of each increase or decrease button-press. In other words those final two buttons let you determine the coarseness of your adjustments. A final button is used to select which point on the curve you're editing in the case that the "parameter" you are editing is actually a curve.
    So if you're tuning the cold-engine enrichment curve, you would tell the ECU to auto-report the coolant temperature on the screen, then navigate to the enrichment-curve and select the point nearest the current coolant temperature. Now, nudge the enrichment number up or down until you like how it sounds, and move on to the next point on the curve as the engine warms up.
    All I can say is: I love easy access!~
  • Adventures and Dash Terminal v1
    Mike Thielvoldt01/22/2016 at 10:02 0 comments
    It has been almost forever since my last log, and to my followers, I apologize.
    In point of fact, I'm terrible at logging things, but I did manage to write down some of the process as I went through it, so here I will bundle not one, but Three logs that I wrote long ago, but didn't post until now:
    From some time in May 2015:
    Greetings from the Road
    The road trip has begun. I write this from the woods outside Mendocino, CA. New to the ECUality arsenal is the dash terminal - an Arduino Mega 2560 equipped with an Xbee and lit LCD display. The unit is powered from an ignition-switched 12V line from the dash fuse panel, so it comes on when the ignition is turned on. The ECU, which is in the engine compartment, communicates with the dash monitor via the Xbee wireless board. All serial functionality can be easily directed to USB or Xbee, so the dash terminal can access the full compliment of commands.
    Currently I am only using the dash monitor it to measure oil pressure, but much more is in store for this unit. Eventually it will enable all of the following:
    Remote control access to common commands (performance mode, log data)
    Remote control selection of readings to display.
    Alerts for electrical faults and unsafe sensor readings
    Control the bow-mounted pneumatic traffic axe. (just kidding. probably)
    And maybe: Remote re-programming (still mulling this over)
    From a couple days later
    Houston, We have a miss
    So far, ECUality has gotten us to our destinations on the road trip, but the steep, winding driving through the coastal redwoods has surfaced a miss of unknown origin, and it appears to be getting worse. A list of observable miss properties:
    • Duration: each miss lasts an estimated 1-10 cylinder fires (it bucks)
    • Frequency: Started once every few minutes, now I get several misses in succession when exiting every curve.
    • Throttle dependency: no definite dependency
    • Warm/Cold dependency: seems to happen mainly when engine is warm, but not 100% sure it doesn't happen cold
    • RPM dependency: More pronounced at low RPM, but no strong dependency.
    Guesses about cause :
    • Closed-loop calibration is sending mixture too lean.
    • Tach signal from Hall sensor is cutting out
    • Air sensor signal is cutting out
    • injector driver is cutting out
    Techniques to determine cause:
    • Add ECU code to check for and report anomalous readings for RPM and air flow
    • Manually enrich the mixture and see if performance improves.
    • Add ECU code to talk to the injector driver via SPI. (Wire library)
    I'm going to do all of these. In this order.
    From some time in June 2015
    Miss Resolved
    ECUality development has slowed, but it has by no means stopped. I have now taken ECUality up the California coast twice to Mendocino and once up to the woodlands near Eureka.
    It hasn't been smooth sailing every time. The trips to Mendocino revealed a miss, which I later diagnosed as being caused by a mistake in the tach input circuit. I had erroneously assumed that the tach signal was the same 0-5V coming from the ignition module as it was going in. It turns out that while the signal going to the ignition module was 0-5, the signal from the module (and to the ECU) was 0-12V. My circuit had protection that kept it from being damaged, but the signal was clipped so severely that the signal to noise ratio was way bad, and occasionally the ECU would sense noise as extra tach pulses.
    The code I wrote to check for anomalous RPM readings (see previous post) was what lighted the way. Every time the engine would miss, I would see RPM fault reports on the dash terminal. This let me know to look at the tach sub-circuit for problems.
    The solution was very simple. I hacked a voltage divider onto the board at the input to the comparator to bring the signal down to the 0-5V level that the Schmitt trigger wants.
  • Low Emissions? - getting there.
    Mike Thielvoldt04/24/2015 at 22:13 0 comments
    Last week was all about measuring emissions. Standards for acceptable emissions levels are set by the state of California, so I decided to see if I could meet the same standard, using the CA-certified test centers. This program is called, "SMOG CHECK".
    Smog Check results before and after:
    • Still room to improve in the low-speed category,
    • Looking quite good in the 25mph (higher-load) category.
    • The last test incorporates a catalytic-converter change, so comparing the first two says more about the ECU.
    • This vehicle does not have EGR, (exhaust-gas recirculation) which means that it depends heavily on the catalytic converter to reduce NOx. You can clearly see how the ECU had little if any effect on NOx, but a big effect on HC and CO. Meanwhile, the new CAT obliterated the NOx
    To get through a smog test (this applies to the STAR test - a stringent test required of older vehicles), a technician (as in: not me) drives the vehicle onto the chassis dynamometer, hooks up a timing analyzer and a tailpipe gas collector, does a visual inspection, then uses the engine to spin up the dynamometer to the required speeds for a test and maintains that speed while the gas analyzer checks the exhaust composition. All the checks and setup require a stable idle, good starting, and a quick transition from idling to under-load auto-tuning to pass the test. Needless to say, this took some work to achieve.
    RPM Idle Stabilization
    The biggest code-hurdle was stabilizing the idle. Because I decided to use all the original sensors, I was restricted to using a single-wire Oxygen sensor. This does not have a heater built in, so when the exhaust flow stops putting enough heat into the sensor to keep it operating, the signal becomes meaningless. This means I could not rely on my O2 sensor to control the idle fuel settings. I learned this the hard way at the first test-center: I had very rough idle, and ultimately couldn't finish the test. Further, the number of re-starts drained the battery so Kim and I had an embarrassing push-start out the lot. Nice try, no dice. I needed another signal to base idle-adjustments on, and there is really only one other choice: RPM.
    The theory is: when we're idling, the engine is out of gear so adjustments to the fuel mixture affect the idle speed. Speaking approximately, we want to be on the lean side of the amount of fuel that gives maximum RPM to prevent carbon buildup, high CO and wasted fuel. The old carburetor-tuning methodology (thanks Dad) goes like this:
    Turn the appropriate screw to lean the mixture until the RPM noticeably drops, then turn it back a set (usually small) amount and there you go. I adopted the same methodology.
    • Do this adjustment only once every X seconds
      • Measure the RPM using a moving average to filter noise.
      • Start leaning the mixture (decreasing fuel) little by little.
      • When the averaged RPM drops by X, stop decreasing.
      • Add X offset back to the fuel input.
      • Apportion the net change to the Local and Global buckets.
      • Re-start the timer
    Of course, the local-global distribution of change has it's own rules, but I'll cover those in a coming update.
    SMOG speculation and What's Next:
    The idle work really showed the advantage of having a heated O2 sensor, both for emissions and for simplifying control heuristics. Further, I suspect the O2 sensor is why I nearly failed for having high CO at 15mph on the last test, when I was so good in that category on the previous test. Between the two tests, I also tried to add a pull-down resistor to the O2 sensor output, and that damaged the new O2 sensor, making me take the last test with an older one. O2 sensor aging is documented as creating a rich-shift. I already have the hardware to go to the latest LS4.9 wide-band O2, which I expect will give far more consistent useful information.
    I do believe the best context for making the next improvements will be on... A... Road Trip. To hell with controlled environments!
    Stay tuned.
  • Tweaking like a Boss
    Mike Thielvoldt04/14/2015 at 08:11 2 comments
    People, we are now
    Automatically tweaking fuel levels while driving!
    I have added logic for determining the appropriate times to engage 3 different modes of injector pulse adjustment, and appear to be correctly applying those adjustments.
    Local v Global changes: A global tweak affects the rate of fuel injection at all RPM's and all loads (air-flows). A local tweak affects the fuel injection rate at a specific RPM and load.
    Map: When I refer to a "Map", I am referring to the 2-d table representing injector pulse duration vs engine load (x) and RPM (y).
    Tweaker modes
    1. Global-only adjustments based on maximizing RPM
    2. global-only adjustments based on O2 sensor
    3. local and global adjustments based on O2 sensor
    Mode 1 takes over when the engine is cold and idling.
    Mode 2 takes over when the engine is warm, but has not been warm for long.
    Mode 3 takes over when the engine has been warm for a while and the engine has been pulling (as opposed to coasting - a state that turns the injectors off) for a minimum amount of time.
    Noticeable power improvement
    The seat-feel is much improved over the original ECU. I did not expect this to be the case yet, but the impetus for the project was, in large, a difficult-to-correct hesitation when accelerating using the original ECU. This has already been eliminated. Woot.
    Next up:
    • fix bug with RPM measurement when engine is off.
    • get a manual SMOG test to measure emissions.
    • Start using Wide-band O2 hardware
    • Build wireless dash-monitor.
  • Function Pointers, meet Serial protocol.
    Mike Thielvoldt04/10/2015 at 01:41 0 comments
    I was already doing this with function pointers:
    task[0] = readAirFlow;			ms_freq_of_task[0] = 50;
    task[1] = readO2Sensor;			ms_freq_of_task[1] = 50;
    But now I'm also doing this:
    ESerial.addCommand(F("Winj"), Map::write, &inj_map);
    ESerial.addCommand(F("rinj"), Map::read, &inj_map);
    ESerial.addCommand(F("Sinj"), Map::save, &inj_map);
    ESerial.addCommand(F("linj"), Map::load, &inj_map);
    It adds a serial command that gets executed on a specific object (in the above example the object is "inj_map" ).
    So after calling the above, when I type: rinj into the serial monitor window, the Arduino runs the "Map::read" function on the "inj_map" object. In this case, that prints the injector map out on the serial port, so you can see what's there.
    So far I have almost 50 commands, which is why I needed to get it down to a 1-liner.
  • Classes, Classes
    Mike Thielvoldt04/08/2015 at 22:43 0 comments
    It's official. This is already the biggest program I have written to-date. And with that realization came a vision of the future: one in which the program got so clunky and large that it stopped being fun to work on.
    So on the heels of my first major project success, and on the edge of diving into optimization, I am cooling off, looking back and doing some extensive housekeeping. (more like re-modeling)
    Where it hurts:
    • When adding new scaling arrays, it takes a while to add all the update, report, load and save functions.
    • When I'm communicating with the arduino, updating new parameters is getting clunky and depending on copy-paste.
    • when I have to add new serial controls, that switch is getting huge, and I can't remember which character means what.
    • range-checking things is getting really tedious.
    Troubling prognoses:
    • many new commands for error checking and tuning will tax my mind even more.
    • adding items to data logger will create similar pains as I'm facing with serial now.
    • new functions for talking to peripherals will make things bigger.
    • the optimizer will not be a good roommate; it needs its own space.
    Treatment plan:
    • encapsulate major types of data-structures into classes to help manage new parameters, maps, etc.
    • created function templates for doing basic things on various simple data types.
    • create wrapper classes to manage lists of objects and actions (think: list of serial commands, list of eeprom-backed parameters, list of logged variables)
    Do you have a suggestion on program design that feels relevant to the above? Please share!
  • First Fire
    Mike Thielvoldt04/02/2015 at 16:04 0 comments
    First (successful) Vanagon test
    Last night, we had our first light-off and the result was very, very promising.
    • Stable idle,
    • Reliable starting (once I got the right setting),
    • All sensor reading made sense,
    • Great throttle response!
    A few of the steps that got me here:
    • Beefed up the rear Arm/Crank control circuit (because starter solenoids take serious amperage!)
    • Verify actual injector pulses with LED on injector driver output.
    • Ask the original ECU for cranking pulse duration (turns out this is totally independent of Air flow or temp.)
    • Add automatic printout of injector pulse duration while cranking (helps tuning to start)
    • Tweak cranking duration so choke-adjusted result matches original ECU's
    • Fire it up.
    • Play with global offset to maximize RPM (at first, until O2 sensor heats enough to come online)
    • Continue tweaking, but now using O2 signal
    • Try opening the throttle - Great result: no hesitation, RPM comes right up.
    At that point my CO meter started going off, so I called it a night. Going to need to handle the exhaust gas.
    What's next:
    • Duct Exhaust away
    • Add Temperature warning (in case it gets hot)
    • Optimization routine
      • Define the optimization modes. I'm thinking: warming up, warm-global, warm-local
      • Define criteria for entering each mode (O2 sensor online, timer, temp, load)
      • Enable the data structures for keeping track of optimization history
      • Add some optimization system auto-reporting
      • Add optimization modes one at a time, testing each
      • Field tests.
    • Take it to SMOG shop to see how we're doing.
  • Characterizing the VW ECU
    Mike Thielvoldt03/11/2015 at 13:43 1 comment
    Goals:
    • Obtain a fuel map from the original VW ECU as a starting-point for ECUality
    • Answer questions about how the original ECU behaved, such as:
      • What aspect of the O2 sensor signal does it care about? (threshold crosses/sec? DC voltage?)
      • Generally, does the optimization routine change the "shape" of the map, or just apply a global offset?
      • How fast does the optimization respond?
    Here, I use an Arduino Leonardo to send signals to the original ECU that simulate sensor data from a running engine. With that stimulus going in, I record the pulse-duration of the injector signal coming out.
    The breadboard between the Leonardo and the ECU contains:
    • a couple RC (low-pass) filters for smoothing PWMs into analog voltages.
    • a couple N-mosfets for handling a voltage-shift (0-5V to 0-12V)
View all 9 project logs
dnczar wrote 09/18/2017 at 18:07 point
I see this is a couple of years old and I hope I'm not out of line here because I'm new to Arduino so much that I know almost nothing but I do something about engines. I don't know if anything you are doing with your project could be part of your "missing" problems but everything you've written along with your smog sheets indicate a classic vacuum issue. Your VW uses a return fuel system and experience would have me starting there. Its parameters are not forgiving and your project is about fuel. From there I would test the block gases recirculating to the intake. If you have AC consider if there is any possible relationship to your missing and AC. Off hand I don't know of any OEM ECU where AC monitoring\sensing isn't integral to fuel delivery. You also mention coming out of curves. Your VW power steering also effects vacuum. Off hand I can't tell you anything about the testing involved but it's based on the greater the steering wheel rotation, the more drastic effect on vacuum along with a more adverse effect on engine performance. Cost effectiveness has led to a lot of system integration that really should not have been used. Vacuum is an obvious cost saver with integration but it also leads to a lot of obscure sources for creating problems.
You've also brought up heated oxygen sensors. You haven't mentioned how much access you have to OEM program parameters but there are some controls here you can play with to fool or cheat OEM programming to accept out of range temperatures as normal. This will not be acceptable for your emission testing requirements though.
Just some thoughts here for your project.
john eckert wrote 10/24/2016 at 04:54 point
This is great.  Will you be posting more details.  I want to build one of these.  Is there a bill of materials?  What is the part number for the connector to the engine harness, the knock sensor and what about the wideband O2 sensor?
Thanks,
John
rakoshi wrote 04/18/2016 at 02:35 point
Extremely exciting project! I have tinkered with the MS systems and am reading up on Speeduino... Love the self tuning approach and overall simplicity.
Mike Thielvoldt wrote 04/19/2016 at 00:39 point
Thanks! That's really great feedback and it's exactly what I'm going for.
counter.culture wrote 04/21/2015 at 13:00 point
you can take this far - if you need some inspiration, look at these guys:
https://www.diyautotune.com/catalog/index.php
some of these megasquirts have source code and schematics available here:
http://www.megamanual.com/MSFAQ.htm
my AVNET rep gave me one of these:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=FRDM-K22F&tid=vanFRDM-K22F
and it is impressive because of the ARM mbed (open source and free to use on ARM processors), Kinetis Design Studio, Arduino R3 3.3V electrical compatibility, and MQX RTOS (open source and free to use on Freescale processors).  if you need CAN bus, you'll need to move up to another controller or external hardware...
Mike Thielvoldt wrote 04/24/2015 at 22:23 point
These are great references.  The MegaSquirt creators and community are some of my go-to sources of knowledge on hardware, and real-engine experience.
counter.culture wrote 04/24/2015 at 23:56 point
cool, didn't mean to be a mother hen.  personally, i know i constantly reinvent the wheel without researching the other wheels already rolling...sometimes that can be really good since having a different perspective can cause some surprisingly different (maybe better) solutions.  sadly, for me it usually means blood, sweat, and tears only to go back to the drawing board.  anyway, i hope you have great success - definitely a fun project on a cool vehicle!
Mike Thielvoldt wrote 04/25/2015 at 01:18 point
Hey, no problem at all.  I appreciate your adding these references since they are totally relevant and helpful sources of information.
In terms of re-inventing the wheel: I can see how, on the surface, this project seems like MegaSquirt's little sister.  In fact, it took me some time and thought to decide what (if anything) I wanted to do differently, and that's an ongoing process.
Right now it boils down to differences in tuning methodology and how much we concentrate on engine physics.  In terms of tuning, I am currently committed to using only firmware tuning strategies, keeping those algorithms as simple as possible, and eschewing separate PC software.  In terms of engine physics, I try to discuss it at as high a level as I can.  My stance is that engines have so many nuances that it's better to find ways to ignore those nuances than to consider them all.
In any case, thanks for bringing up these points.  It helps us understand what ECUality1 is.
Josh Stewart wrote 04/08/2015 at 04:55 point
Nice work! Do you have the code available anywhere? I maintain the Speeduino (http://speeduino.com) project and there's probably a lot of overlap here if you're interested in any potential cooperation.
Mike Thielvoldt wrote 04/08/2015 at 06:02 point
Thanks, Josh.   I found speeduino a couple days ago and dove in; really liked the presentation on YT from last year.  I just added a link to ECUality's GitHub repo.  It's a work in progress, as I'm undergoing a major re-factor right now, putting various items (Maps, Scales, Parameters  -  the equivalents of your 2Dtables and 3Dtables) into classes.  But I will definitely post when I have a release.
        I'm planning my optimization/autotuning heuristics, and I'd really like to chat about that and other things.  Any time really.
gthielvoldt wrote 04/03/2015 at 01:10 point
Great project, i just happen to have a V-8 or 2 or 3 that need some serious help.
