Update!
The complete DIY kit is for sale on Tindie:
https://www.tindie.com/products/skrodahl/muffsy-relay-input-selector-kit/
The code, gerbers and Eagle files all reside here:
https://github.com/muffsy/RelayInputSelector
Instructions on muffsy.com:
https://www.muffsy.com/muffsy-relay-input-selector-4.html
Features
- Four stereo inputs and one mute circuit, switched with Panasonic TQ-2 relays
- One stereo output
- Controlled with ESP32
- Space for the ESP32S/NodeMCU, with break-out for all pins
- IO pins go high when activating a relay, can be used for indicator LEDs
- Power/GND for ESP32 and relays separate from signal power/GND
- Fully open source, no strings attached
Schematics, Downloads and other resources
- ESP32 Eagle library: https://hackaday.io/project/46280/log/87314-esp32s-devkit-eagle-library
- Schematic (with ESP32): https://hackaday.io/project/46280/gallery#a3e1b4be8cf593af3733282c43617b2c
- Schematic (without ESP32): https://hackaday.io/project/46280/gallery#cbabb3ed6913ae0336a70ea0561f796d
- Component list: https://hackaday.io/project/46280-muffsy-stereo-relay-input-selector#menu-components
- Mouser Shopping Cart: https://www.mouser.se/ProjectManager/ProjectDetail.aspx?AccessID=ff6d49ef76
(Updated: 2019-03-29)
- Source code, Eagle project files and Gerbers are available on Github:
Eagle project files, Gerbers and source code found on these project pages are outdated, but kept for reference. Go to Github for the latest revisions.
ESP32 Module
The ESP32 module used for this project is the one called ESP32s NodeMCU. It's got 2x19 pins, no pin labels on the top, and a white bottom side with the text "NodeMCU ESP-32S v1.1"
The ESP32 development kit has a CP2102 USB to UART bridge, drivers are available from Silicon Labs:
Information on how to program the ESP32 using the Arduino IDE is available from Espressif. The board name in the Arduino IDE is "NodeMCU-32S", as it says on the backside of the board:
Espressif's "IoT Development Framework" IDF/SDK is available here, along with a lot more information:
M.R. Inc
andyhull
C. Prichard
Great job skrodahl! Cangratulations! Furthermore, 2 outputs for a simple H-Bridge for motorized potentiometer would be very useful. Up and down from remote controller, volume buttons. Is hard to make the modifications in code? I am not a programmer but I like to do some projects.
