Gradatim Ferociter
A project log for ИГГ1-64x64M Adventure
Driving and use the ИГГ1-64x64M. High voltage vacuum dot-matrix display made in Ukraine in the 80's by Gazotron
muthMuth 03/02/2018 at 19:040 Comments
Step by step...
I'm quite advanced now with the soldering of the boards. However I'd like to test the multiplexing of them.
First I start to think how mount everything on the screen back :
It fits very sharp on the diagonal.
I decided to switch to a smaller micro controller, one of the PIC I already have and used for the LCD big_clock. With it I can easily scan the boards and pins plus enable serial interface. It have plenty enough of RAM as well.
Then I cabled 2 boards for 16x16 pixels drive :
And well, it start to be more and more likely this strategy could work !
Next step: more cabling ;)
