4096 pixels
A project log for ИГГ1-64x64M Adventure
Driving and use the ИГГ1-64x64M. High voltage vacuum dot-matrix display made in Ukraine in the 80's by Gazotron
muthMuth 03/09/2018 at 13:054 Comments
That was a job. After soldering 736 components and approximately 160 wires, the 30 years old display is alive.
Some pictures of the back (please apologize the wire-mess) :
And the front :
And below the serial connection in action (115200 bauds, 5 frame per second, images taken around the mouse cursor of the computer) :
As you can see there is still some artifacts, especially on the screen bottom. I still have to adjust the cathode bias resistor value.
A funny fact is the screen is buzzing, adding a very old fashion touch to the retro style, in addition to remind you there is 360 volts in here.
Next step: a convenient and safer case !
Russell Borogove wrote 03/18/2018 at 14:44 point
Fantastic!
Muth wrote 03/18/2018 at 18:47 point
Thanks ;)
Wenting Zhang wrote 03/09/2018 at 15:36 point
This is really cool!
Muth wrote 03/09/2018 at 16:19 point
Thank you! Seeing it working is quite rewarding :D
