Vertical Blinds Hanger
I made these hangers because they always break and you can only buy in packs of 500 or 1000 pieces. I thought this model will be useful.
Because I am a student, I want to be considered at the student section of the "Repairs you can print", because i'd love to have my own 3D printer. The original hanger was a bit too thinner and was too flexible. The second hanger had a too thick hole and the hook couldn't fit in. The third hanger was perfect. Everything was ok, the hook fitted inside the hole, and was thick enough.
   This project is ongoing because there are diferent types of blinders with different shapes and sizes. I try to find a "middle model" or a adjustable model that will fit in every sinle type of blinder.
    This model was made with Creo Parametric 3.0
     How was this made?
                 I just took a broke Hanger and I measured its lenght and its width, I                                measured its hole to fit the hook in and I started model it on my laptop. When                    I was sure its finish, I turned on 3D printer and I gave it a try.
                  Fortunately the model was a succes and I begun to make more.
      How the idea came out?
      Everything began when I seen there is too much light in my room because a couple of blinders were missing.
perdea.prt.1
This is the .prt model. If you need to modify the dimensions just download this file, open with your 3D modeling program and edit it. Enjoy :)
1 - 149.84 kB - 02/03/2018 at 10:11
Download
perdea.stl
This is the .stl model. If you need a Blinder Hanger, you have just to download this file and begin a print. Easy like that :)
- 144.03 kB - 02/03/2018 at 09:55
Download
  • 1
    What material i prefer?
    I recommend ABS because is a strong material but works well with any other material.
  • 2
    Infill
    Print it with close to 100% infill to be a strong piece.
View all instructions
mircea.fizitec wrote 02/05/2018 at 18:18 point
I really need some of these!
