Pi Supply added
A project log for RaspBox - Home Automation & Cloud
Voice controlled home automation and personal cloud using a Raspberry Pi
rodolphehRodolpheH 04/15/2014 at 16:370 Comments
Just a small project log to say that I've installed a Pi Supply on my Raspberry Pi in order to bring ATX-style power supply to it.
The Pi Supply website gives a script to run on the Raspberry Pi to detect a button press from the Pi Supply and halt safely. Since I'm using Arch Linux with no X and the Pi Supply script is made to be run on an LXDE environment, I though I should make my own script and systemd service.
You can find it on my GitHub. If you wish to install it on your system, you should do:
# git clone https://github.com/rodolpheh/softshut-pi.git
# make install
If you want to remove it, you can do:
# make remove
If you want to start the service on boot, do:
# systemctl enable softshut
After rebooting you should be able to shutdown safely your Raspberry Pi just by pressing the soft shutdown button on the Pi Supply.
Note: you need python2 and python2-raspberry-gpio to run this script. You can find the last one in the AUR (only for Arch Linux users).
N.B: I've also installed a Pololu U3V12F12 to get 12V for the TX433. For the moment, I can't tell if it's better since I'm more working on my Sci-Fi contest project than on my RaspBox but I will get you informed soon.
