1Step 1
HARDWARE:
XBee Wireless Components:
-SparkFun XBee Shield XBee Shield (WRL-12847)
-SparkFun XBee Explorer USB (WRL-11812)
-XBee 1mW Wire Antenna - Series 1 (802.15.4) (WRL-08665) (2)
Moving Parts:
-Power HD High-Torque Servo 1501MG From www.pololu.com
-SparkFun Micro Gearmotor - 90 RPM (6-12V) (ROB-12285) (2)
-Eurotool Pro-Electric Bead Reamer (for drill)
-Huhushop(TM) 12V DC DIY Dosing Peristaltic Pump
All Other Electronics:
-Arduino Uno
-Adafruit Proto Shield for Arduino Kit - v.5
-H-Bridge Motor Driver (SN754410)
-IC Socket - for 16-pin 0.3" Chips
-DROK LTC1871 Volmeter Didplay 3.5V-30V DC Volt Converter (2)
-Cutequeen Trading White 5050 48SMD 48-SMD LED Light-N-Channel Power MOSFET F 12N10L (2)
-Juno Power NOVA BLOX 4000mAh External Battery (2)
-9 Volt Battery
Brackets, Supports, and Connectors:
-Alloy Steel Socket Head Cap Screws http://www.mcmaster.com/#socket-head-cap-screws/=v...
-1/2" 6-32 (30)
-1.25" 6-32 (5)
-1" 6-32 (5)
-Hex Locknuts 6-32 (60) http://www.mcmaster.com/#hex-locknuts/=v0waff
-Stainless Steel Washers http://www.mcmaster.com/#standard-washers/=v0w9cc
-Spacers (1/4", 1/2", 3/4", 1") http://www.mcmaster.com/#unthreaded-spacers/=v0wa...
-Actobotics Side Mount Bracket (pair) (ROB-12252) (8)
-Actobotics Servo Mount - Servo Plate C (ROB-12237)
-Actobotics Channel Standoff - Aluminum (Threaded) (ROB-12132) (6)
Material:
-1/8" Acrylic
-1/16" Acrylic-7/8" Acrylic tube (interior dimension) to hold ink or biomatter
SOFTWARE:
-Rhinocerous (With Grasshopper and Firefly Plugins)
-ReacTIVision Version 1.5 http://reactivision.sourceforge.net
-Arduino 1.0.6 http://arduino.cc/en/Main/Software
Anh Vu
