Synthino XM Polyphonic MIDI Synthesizer
a powerful polyphonic synthesizer with unique features
Starting from
$139.00
nootropicdesign has 129 orders / 3reviews
Ships from United States of America
The Synthino XM is polyphonic synthesizer with unique features running on an ATxmega128a4u microcontroller. It is compact, well-constructed, open source, and absolutely beautiful. Most importantly, it is really fun to play whether you are a musician or you just want to make some noise.
Synthino XM is a polyphonic, multitimbral synthesizer with many features:
  • 5-note polyphony for superb playability
  • 12 waveforms, 4 drum samples
  • 12-bit audio at 25KHz output rate
  • 4 MIDI channels, each with separate waveform and ADSR envelope settings
  • low pass filter with cutoff frequency and resonance controls
  • 2 independent low frequency oscillators (LFOs): pitch and filter
  • selectable waveform for LFOs
  • 1V p-p audio output voltage with enough current to drive headphones
  • arpeggiator mode, up to 16 notes
  • 4 arpeggiator patterns: up, down, up-down, random
  • 4 built-in arpeggiator chords or use MIDI to specify up to 16 notes
  • arpeggiator pitch transposition control
  • tempo control with MIDI clock input
  • 16-step live performance "groovebox" sequencer
  • pitch fine-tuning adjustment
  • programmable/upgradable over USB
View project log
