gasket.stl
The gasket that goes between the fixation base and the sun skirt.
Standard Tesselated Geometry - 84.45 kB - 03/11/2016 at 01:07
Download
top front view, box closed, hi res
JPEG Image - 431.79 kB - 02/20/2016 at 02:08
Preview
Download
Front view, box closed, hi res.
JPEG Image - 747.99 kB - 02/20/2016 at 02:08
Preview
Download
The top view in high res, with box opened.
JPEG Image - 1.17 MB - 02/20/2016 at 02:07
Preview
Download
PareSoleil.stl
The sun protection for the camera (for better image quality). A piece of plexiglass should be glued in this to have a waterproof box. In future version i will include a grove for a rubber o-ring.
Once printed, it screws on the support that's glued to the derivation box.
Standard Tesselated Geometry - 88.58 kB - 02/20/2016 at 00:45
Download
PareSoleil.scad
The base that gets glued on the derivation box, and on which the sun protection for the camera module gets screwed on + the sun protection (scad file, if you want to adjust things)
- 1.97 kB - 03/11/2016 at 01:07
Download
baseFixationPareSoleil.stl
Standard Tesselated Geometry - 84.45 kB - 02/20/2016 at 00:44
Download
fixPlate.scad
The fixation plate to secure the raspberry pi and the camera module in a derivation box
scad - 1.89 kB - 02/20/2016 at 00:44
Download
fixPlate.stl
Standard Tesselated Geometry - 287.83 kB - 02/20/2016 at 00:43
Download
