ctc_mk8_extruder_right_base.stlmaterial feeder part 1 (light green 3D printed part)Standard Tesselated Geometry - 99.59 kB - 02/04/2018 at 18:02 |
ctc_mk8_extruder_right_lever.stlmaterial feeder part 2 (light green 3D printed part)Standard Tesselated Geometry - 111.90 kB - 02/04/2018 at 18:02 |
feeder_motor_mount (1).stlFeeder motor mount (light blue 3D printed part)After a while of printing you pause the print and insert the nut in your 3D printed part. You will see when the nut hole appeare and when it is starting to close then insert nut for bowden tube. Standard Tesselated Geometry - 72.15 kB - 02/04/2018 at 18:00 |
Duct.stlFan duct (dark green 3D printed part)Standard Tesselated Geometry - 110.24 kB - 02/04/2018 at 18:00 |
Bowden_clamp_v2.stlhotend mount part 2 (white 3D printed part)Standard Tesselated Geometry - 251.84 kB - 02/04/2018 at 17:59 |
Bowden_mount_v2_with_endstop.stlHotend mount part 1 (white 3D printed part)Standard Tesselated Geometry - 514.73 kB - 02/04/2018 at 17:58 |
