UV-badge
wearable UV Index & weather sensor
Keychain sized UV and environmental sensor
The aim...
...is to build a small, wearable instrument to check UV index, air temperature, humidity and air pressure.
Why is it important? (the problem description)
Natural sunlight contains UV rays, they are important for life (e.g. body's vitamin D production)
However, too much UV exposure can cause serious health problems, so you have to achieve the optimal UV dose for your body.
On the other hand, tracking and predicting weather changes has been desired by people for a long time. The basis of weather observation is still the measuring and recording of barometric air pressure, temperature and relative humidity.
Use cases
Avoid Sunburn
On the one hand you can check the current UV index, on the other hand you can keep track of the accumulated UV exposure checking the "UV index hour" value, which correlates with the UV erytherma dose.
By monitoring the UV index and the total UV exposure you can protect yourself in time (e.g. by applying sunblock, using some shading...)
Predict weather changes or storms
The rule of thumb is, when the pressure is stationary or slowly rising, you can expect nice weather. Falling pressure is followed by bad weather, and quickly falling pressure usually means that a storm is coming.
Estimate elevation
Atmospheric pressure changes ~12 mBar / 100m. By reading the pressure difference, you can easily calculate the altitude change.
Indoor humidity control
Too low or high humidity can be uncomfortable, check the indoor humidity then turn on the humidifier if it's too low, or if it's too high you can decrease it by airing the room or turning on the air conditioner.
Observe the trend in the changes of the values
The observation of the changes in the environmental characteristics can also be meaningful.
UV Index and sunburn...
Check out this project log for calculation details.
System Design Diagramm
System design document
https://github.com/x-labz/UV-badge/blob/master/doc/system%20design%20v-1.0.pdf
Technical features
Atmel AVR ATTiny for reading the sensors and displaying the data.
Pico-power design, to extend battery life.
Custom 3D printed case
Lightweight: 11g
Dimensions: 50mm * 32mm * 8.1 mm
Read the story about the re-design reasons in this project log
Finals video
Semifinals video (the details)
Quarterfinals video (the development process)
Bonus Features:
Altimeter - https://hackaday.io/project/4706/log/25164-altimeter
Arcade game - https://hackaday.io/project/4706/log/23955-bonus-feature-games
License
UV-badge device is licensed under the GNU General Public License v3.0.
  • 1 × Sharp Memory LCD 128px * 128px - monochrome
  • 1 × ATMEL ATtiny861A picopower risc cpu
  • 1 × CR2016 coin cell
  • 1 × some resistors & cap's
  • 1 × BME280 enviromental sensor
View all 7 components
  • Low power challenge
    x-labz02/01/2023 at 21:08 0 comments
    Some information for the low power challenge:
    According to the past years experiences, the device is capable to run for more then 1.5 YEARS (!) on a CR2016 coin cell battery!  It's half size of the most common cr2032
    Don't forget, that the device takes environmental measurement in every 15 min, however the display operates only on user interaction.
  • SALE! - last two pieces
    x-labz08/09/2016 at 07:58 2 comments
    You can buy the last sample pieces for $55 / item. (postage included)
    The adapter clip for the in-system-programmer will be $10 / piece. The adapters will be shipped few weeks later, because those are out of "stock".
    Features:
    - temperature measurement: °C / °F
    - barometric pressure: mBar
    - altimeter: meter / feet ( you can zero the altitude value, and the device will show you the difference when you eg. climb a hill, or go up to a skyscreeper)
    - UV index
    - the device takes a measurement in every 2 sec when in active mode, after 30 s left unattended falls to sleep, but takes measurement in every 30 min. so you can have an ~12 hour chart of measure data.
    The "UV index hour" ( UVIh - the accumulated or summed UV index) was removed, because after some experiments I found it quite useless (the device should face very precisely directly towards the sun for hours to get acceptable result)
    Anyway you can measure the actual UV index by turning the sensor directly in the sun direction.
    Short VIDEO of the current firmware in action:
  • V4.0 firmware published
    x-labz06/06/2016 at 19:23 0 comments
    Check out the latest firmware on github: https://github.com/x-labz/UV-badge/tree/master/firmware/v4.0
  • Updated User's guide
    x-labz06/06/2016 at 15:16 0 comments
  • Extending battery life
    x-labz10/29/2015 at 19:56 0 comments
    With the new improved battery management feature the device enters 'sleepwalking' mode after 30 sec. In the sleepwalking mode the display is not refreshed but the data is still acquired for the log.
    Let's compare the operation modes:
    ActiveSleepwalking
    Measurement rateevery 2 secevery 512 sec
    Display refreshevery 2 secno refresh
  • Altimeter
    x-labz09/14/2015 at 16:21 0 comments
    With this custom firmware the UV-badge sensor hardware can be used as a precision ALTIMETER!
    Check out the elevator test:
  • New function - imperial units!
    x-labz08/27/2015 at 08:12 0 comments
    The new v2.1 firmware implements the unit change function. Using the left-hand button, you can change the temperature unit from °C to °F, and back.
    The barometric pressure can be displayed in mBar and mmHg as well.
  • Bonus feature - games!
    x-labz08/23/2015 at 20:10 0 comments
    Play arcade game on the UV-badge hardware!
    ~20 FPS @ 8 MHz.
    Only 6.5 KB ROM and 145 B RAM is required.
    ...and remember, there is no frame-buffer! The application generates the picture line-by-line for every frame. The CPU can't store the whole picture in it's small RAM, and the LCD is "write only'' , you can't read the data back!
  • Samples are ready to ship!
    x-labz08/09/2015 at 13:55 4 comments
    The sample devices for the 'best product' category are fully assembled. They will be shipped with UPS.
  • Sample circuits
    x-labz07/29/2015 at 19:34 0 comments
    The sample devices are ready for #bestproduct prize. The 3D printed cases are still in production.
View all 22 project logs
  • 1
    Step 1
    Order the components
    Order the components listed in the BOM (bill of materials)
    BOM link
    Additionally you will need some more components for the programming adapter:
    Mouser ID
    538-78864-1001
    649-54202-G3003LF
  • 2
    Step 2
    PCB
    Order the PCB for the main circuit and for the programming adapter; don’t forget, that they should be 0.5 mm thick! Otherwise it will not fit in the case.
    Design Files
    Programming adapter
    Design file
  • 3
    Step 3
    CASE
    Get the case and the programing adapter clip 3D printed. For the best result use SLS technology, e.g. “Strong and flexible” nylon material at shapeways.com
    Design Files
    The parts of the case are connected with thin plastic strings, separate them using a sharp knife or scalpel.
    3D printed programming adapter clip
    Design file
View all 15 instructions
yOyOeK1 wrote 02/02/2023 at 00:17 point
Nice!
hvktqstuan93th wrote 12/30/2016 at 03:43 point
why did you choose that is not ATMEL ATtiny861A other microcontroller? thank you :))))
x-labz wrote 12/30/2016 at 09:11 point
Hi,
It seemed to be a good choice... One important feature is the Pico Power thing.
hackaday wrote 08/10/2015 at 12:44 point
Nice project. I did something similar using the SI1132 sensor and buttons and beeps only for the interface. I wasn't happy, though, that the sensor could be fooled by artificial light or window light.
I'm glad I saw this as I was not aware of the ML8511. I'm testing the GUVA-S12SD breakout from Adafruit but it's not a part you can buy from Digikey or Mouser yet, while the ML8511 can.
x-labz wrote 08/10/2015 at 13:03 point
Hi, I agree with You. The Silabs UV sensors 'only' estimate the UV index by measuring the ambient light intensity. The ML8511 measures in the UV spectral range, so in cloudy weather should be more accurate.
mr.jb wrote 08/01/2015 at 10:44 point
This display might be a cheap alternative....
http://www.electrodragon.com/product/12864min-graphic-lcd/
x-labz wrote 08/02/2015 at 19:29 point
hey,
thanks, cool! but don't forget, the sharp memory lcd has uniquely low power consumption! (max 40 uA)
mr.jb wrote 08/02/2015 at 20:21 point
How much RAM does it need ?
Have you released any code ?
hackaday wrote 08/10/2015 at 12:36 point
Nice. I was looking for something like that which was 3.3v and sunlight readable. I have a bunch of Nokia 5511 displays but they all seem to suffer from some kind of display rot.
icewalker wrote 07/14/2015 at 18:03 point
Very nice project, do you plan to release some more technical info like open source code and schematics? That would be nice... just wondering, I wish you a lot of success!!!
x-labz wrote 07/14/2015 at 18:26 point
Yes, definitely! stay tuned on twitter:  https://twitter.com/xLabzNet
icewalker wrote 07/14/2015 at 18:38 point
definitely cool, that's a real spirit!
I checked the twitter link (I must admit I am not so familiar with this technology, but just created an account and you have a follower) and the photo are impressive, I am looking forward to it...
Darren Enns wrote 07/08/2015 at 22:33 point
Cool!  I am very new to 'Hackaday'.  Do people who invent clever projects like this typically offer them for sale when they are complete i.e. are you planning to do so?
x-labz wrote 07/09/2015 at 08:43 point
Hi
depends on the proposal.  :-)
MicroPrototype & Design wrote 05/02/2015 at 23:35 point
Do you have a link for this display ?
Data Sheet and price.
Thanks
j0z0r pwn4tr0n wrote 05/03/2015 at 00:56 point
https://www.adafruit.com/products/1393
It's forty dollars here, library provided. Google "Sharp memory display" and maybe you can find a more viable bulk supplier if you're looking for something to go in an end product.
MicroPrototype & Design wrote 05/03/2015 at 01:30 point
Must be a typo, the display is 96x96 pixels   :-)
j0z0r pwn4tr0n wrote 05/03/2015 at 03:01 point
Ahhh, I copied and pasted without even really thinking, lol.
http://www.mouser.com/Search/m_ProductDetail.aspx?Sharp-Microelectronics%2FLS013B7DH03%2F&qs=La0%252b8xZSm19d3Mbp4mkNrQ%3D%3D
Here's the link to the 128x128 version. $18 for one, although I think it is just bare screen and ribbon cable.
MicroPrototype & Design wrote 05/03/2015 at 14:37 point
Yes, Thank You. This is just what I have been looking for.
ch.dugasduvillard wrote 04/27/2015 at 10:01 point
What sensor do you used for the touch button ?
x-labz wrote 04/27/2015 at 13:12 point
analog input of the controller, but I plan to remove it from the design in the next version. I'll use a tactile switch, because power consumption reasons.
gmwatbot wrote 03/30/2015 at 21:52 point
Just brilliant. Any data logging on board?
A spin off from this board might be something I'm dying for: http://donotbeonfire.neocities.org/
x-labz wrote 03/31/2015 at 04:41 point
the measurements planned to be stored in every 30 minutes, keeping a whole day log, just to be able to see the trend
x-labz wrote 03/25/2015 at 07:14 point
Good idea! The bosch sensor just simply didn't come across.  :-)
Will Rea wrote 03/24/2015 at 22:25 point
Just wondering what made you going with the lps25hb and si7020 and not something like the bme280?
