Hey everyone!
In this log I will successfully turn the dial up to 11 increasing the Franken pumps flow to 850GPH.
Everything is pretty straight forward. 36v 500 watt power supply. New HV ESC. 5 Gallons of water and a messy workbench...
Anyways, here is the most recent test!
I have ordered a 48V 800w power supply that should get me up to about 54v with the V-Adjust trim feature. The pump has already met and exceeded my specifications.... Now I just want to push it to the limit! because of.... well, science!
Hope everyone enjoys!
Andrew Mayhall
