Pure Mechanic Motor
both a securized, by a fluid part, and a unsecurized exponential mechanic generic system
if you are not able to learn, the opposite of you did learn, by reading & follow comments in pmm.scad opened in openscad http://www.openscad.org/downloads.html
this project is not for you (return to your brainwashing)
unzip the gears lib and put pmm.scad in the same folder
open it with openscad follow instructions and render (adjust the distance if needed)
according to your need modify it and make your model by hand or stl => 3d print
https://www.thingiverse.com/thing:2123204 is used in pmm.scad (mirrored too)
else details in pmm.scad
pmm.scad
both un/securized mechanic in openscad with easy instructions even for childs education
x-openscad - 9.41 kB - 04/05/2018 at 10:50
Download
343_license_en
free for free license
343_license_en - 666.00 bytes - 02/24/2018 at 10:17
Download
openscad_gears_english.zip
used in pmm.scad; put it the same folder
Zip Archive - 14.30 kB - 02/21/2018 at 20:24
Download
View all 7 project logs
  • 1
    to build
    follow the details in pmm.scad, render part by part to have ideas of what you need and modify to suit your need ;)
View all instructions
esot.eric wrote 04/05/2018 at 07:19 point
Intriguing, so here's a 'like'... Can yah post a picture?
malvasio.christophe wrote 04/05/2018 at 10:16 point
no as i can't include the license in it
i'll update later today so openscad install will give you the chance to see and understand both un/securized mechanic
updated pmm.scad ; )
esot.eric wrote 04/08/2018 at 05:43 point
That's unfortunate, pictures really help to draw attention to prize-entries... I'll have to check it out next time I've got a machine running openscad!
