An attempt at making a basic LIDAR. I worked on this back in 2015. Circuit creates a high current pulse to drive an IR LED, and is built around two TI TDC7200 timers to measure the time until a return pulse is received. The first timer measures the leading edge of the pulse, and the second timer measures to the trailing edge of the pulse. This provides two measurements to help cancel out thresholding effects when the pulse edge is not sharp. A high speed comparator is used to threshold against a DAC output. An 8 bit processor is used to orchestrate.
I ended up giving up on it for two reasons: I accidentally supplied 5v to the circuit, and the sensitive timers have a max of 3.6v and they got hot. I also realized that the parts count was getting huge to get this to work, and that the range would not be that great. Posting here in case it gets anyone else thinking.
