I am using @Akiba's Freakduino as a guide
This project includes:
  • AT86RF212B - Wireless Module
  • AT328P microprocessor (to use Arduino IDE)
  • Level shifting for programming (probably in the cable)
  • Programmer hookup - Tag Connect?
  • Battery hookup
  • Power supply pads for testing with benchtop pwr supply
  • 915 MHz Antenna (either piece of wire or PCB)
Things to work out:
  • Communication Range between modules
  • How to make a mesh network (collab with Akiba)
  • Power draw
  • How to program the module via SPI
