Fire starter
A project log for TiRStove
A 450g Titanium Rocket Stove
mr.jbmr.jb 11/22/2015 at 08:540 Comments
Fire piston
Made in titanium is my favorite
http://www.jsme.or.jp/tsd/ICBTT/conference02/MasanoriOGATA.html
http://www.oberlin.edu/physics/catalog/demonstrations/thermo/firesyringe.html
http://www.bbc.co.uk/bang/article_firepiston.shtml
Scale it up : multi piston fusion ;-)
https://youtu.be/2m9kC1yRnLQ?t=612
Smouldering - char cloth
low-temperature, flameless form of combustion, sustained by the heat evolved when oxygen directly attacks the surface
Smouldering fuels are generally porous, permeable to flow and formed by aggregates (particulates, grains, fibres or of cellular structure). These aggregates facilitate the surface reaction with oxygen by allowing gas flow through the fuel and providing a large surface area per unit volume. They also act as thermal insulation, reducing heat losses.
http://fire.nist.gov/bfrlpubs/fire95/PDF/f95127.pdf
Parabolic mirror
Mirror size : 8cm diameter
Sun : 300 W/m2 ( November Sweden )
The effect hitting the mirror : 0.04*0.04*π*300 = 1.51 W
Let's say that 70% of the incoming radiation i reflected to the focus dot 0.4 cm diameter, thus resulting in a 0.7*1.51 = 1.056 W at an area of 0.004*0.004*π=0,00005027 m2
Emissivity = 0.9 "wood" ( chaga - tinder fungus )
http://www.engineeringtoolbox.com/emissivity-coefficients-d_447.html
Stefan-Boltzmann Law
T=(1.51/(0,00005027*5.6703E-8*0.9))^0.25 - 273 => 600 °C
http://www.powerfromthesun.net/Book/chapter08/chapter08.html
http://www.forbes.com/sites/ethansiegel/2015/06/22/its-the-power-of-quantum-mechanics-that-allow-the-sun-to-shine/
http://solar-center.stanford.edu/FAQ/Qshrink.html
Arc lighter ( single transistor fly back/ spark gap transmitter / plasma arc)
12000K ?
https://en.wikipedia.org/wiki/Ionized-air_glow
http://sciexplorer.blogspot.se/2013/01/lightning-part-3-lightning-bolt.html
http://3.bp.blogspot.com/-0Cl5lJLuARA/UZd0hMepiYI/AAAAAAAAAKM/hnvzMZxp7P8/s1600/Spectrum+Rec.jpg
Spark gap transmitter
https://nationalmaglab.org/education/magnet-academy/watch-play/interactive/lodge-s-experiment
https://www.youtube.com/watch?feature=player_detailpage&v=YSf93g0heUA#t=73
http://www.arrl.org/files/file/History/History%20of%20QST%20Volume%201%20-%20Technology/Kennedy%20N4GG.pdf
http://ashishrd.blogspot.de/2015/11/rediscovering-magic-of-wireless.html
Scale it up : Quasar - Plasma focus fusion - "lighter" ;-)
https://www.youtube.com/watch?v=-ypME6Rh8lA&feature=player_detailpage#t=14
https://youtu.be/xjiqJfUIWhA
Go with the flow
https://www.youtube.com/watch?feature=player_detailpage&v=yhKB-VxJWpg#t=613
