Robo Rudolf
A project log for Ultimate running aid
Eliminate everything from running but the running part.
lion-mclionheadlion mclionhead 12/15/2018 at 04:360 Comments
To make the miles more interesting, the decision was made. Originally wanted to discard the ears & just use the antlers, but didn't have the stomach to tear it all apart, despite being $1. The intact antlers are easier to break down. The nose was an LED light bulb with a red LED replacing the white LEDs. The red LED needed a diffusing cover in the form of translucent heat shrink which is no longer made.
