Installed the ancient XBee Pro 900's & got instantly perfect results. These were the only true frequency hoppers that really work. The connection time is still a very long 30 seconds & the power consumption is 100mA. They could be reconfigured for lower power, but the 2.4Ghz ran at 100mA for 5 years. The packet rate is only 25Hz.
The ancient XBees are still the same outrageous price as 10 years ago.
