This project is based on Raspberry pi 1 and UART fingerprint scanner.
It is very easy to build and control.
Fingerprint scanner is able to store 1000 fingerprints.
You can add new one, delete or even download image of scanned fingers.
Everything is controlled via telegram bot / or web-interface(in future)
Adding new finger is very easy:
*Push "Add new finger" in telegram bot and place your finger to scanner two times
*Write the name of the person, and it will be stored in text file with the number of the fingerprint( it is need to delete specific finger. )
* As soon as you added new finger, push "Start search", place your finger and this time relay will change its state
* Connect relay to door and you do not need any keys no more, use your finger to enter.
Preparation
For this you will need an RPI1/2/3 (it doesn't matter)  with the Raspbian installed. You can get it here: https://www.raspberrypi.org/downloads/raspbian/
Boot up Raspbian and make some configuration.
sudo cp /boot/cmdline.txt /boot/cmdline_backup.txt
Edit the file:
sudo nano /boot/cmdline.txt
Delete any parameters involving the serial port "ttyAMA0" or "serial0" if it exist, which in this example is:
console=ttyAMA0,115200
Which gives:
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
Press CTRL+X to exit and save .
Next, you have to disable the serial getty service:
sudo systemctl stop serial-getty@ttyAMA0.service
sudo systemctl disable serial-getty@ttyAMA0.service
Enable UART
Enabling UART with minimum core frequency:
pi@raspberrypi:~ $ sudo nano /boot/config.txt
# Enable UART
enable_uart=1
Enabling UART with maximum core frequency:
# Enable UART
enable_uart=1
force_turbo=1
Install Python library for ZFM fingerprint sensors
~$ echo "deb http://apt.pm-codeworks.de wheezy main" | sudo tee -a /etc/apt/sources.list
~$ wget -O - http://apt.pm-codeworks.de/pm-codeworks.de.gpg | sudo apt-key add -
~$ sudo apt-get update
~$ sudo apt-get install python-fingerprint
~$ sudo usermod -a -G dialout pi
~$ cd /usr/share/doc/python-fingerprint/examples/
In my case i host telegram bot apart from rpi, so i created ssh secure public key to communicate with raspberry.
Login to server where the telegram bot is hosted:
server1:~# cd /root/
server1:~# ssh-keygen -t dsa
Generating public/private dsa key pair.
Enter file in which to save the key (/root/.ssh/id_dsa): <PRESS ENTER TO ACCEPT DEFAULT>
Created directory '/root/.ssh'.
Enter passphrase (empty for no passphrase): <PRESS ENTER FOR NO PASSPHRASE>
Enter same passphrase again: <PRESS ENTER FOR NO PASSPHRASE>
Your identification has been saved in /root/.ssh/id_dsa.
Your public key has been saved in /root/.ssh/id_dsa.pub.
The key fingerprint is:
41:03:aa:dc:cc:b9:39:50:65:bc:ee:7b:36:d2:64:7a root@server1
Copy the public key from 'server1' to 'raspberrypi'...
server1:~# scp /root/.ssh/id_dsa.pub 192.168.0.2:/root/.ssh/authorized_keys
You can test it with
ssh root@192.168.0.2
Create Telegram Bot
You can check official guide on how to do this in just few steps:
https://core.telegram.org/bots#3-how-do-i-create-a-bot
Install some dependencies for bot
sudo apt-get install libreadline-dev libconfig-dev libssl-dev lua5.2 liblua5.2-dev libevent-dev libjansson-dev libpython-dev make
apt-get update
apt-get -y install python-pip
python get-pip.py
pip install pytelegrambotapi
pip install simplejson
Run BOT
(in my case i host bot on virtual server)
# -*- coding: utf-8 -*-
import config
import telebot
import os
import time
import requests
import subprocess
import simplejson
import sys
from telebot import types
from telebot import util
bot = telebot.TeleBot(config.token)
@bot.message_handler(commands=['help', 'start'])
def begin(message):
    markup = types.ReplyKeyboardMarkup(selective=True,row_width=2, resize_keyboard=True)
    markup.add('🔍Start search', '👆🏻Add new finger', u'✅Status')
    msg = bot.reply_to(message, 'Choose the action', reply_markup=markup)
    bot.register_next_step_handler(msg, process_step)
@bot.message_handler(commands=['name'])
def name(message):
  sent = bot.send_message(message.chat.id, 'Type name')
  bot.register_next_step_handler(sent, hello)
def hello(message):
    open('username.txt', 'w').write(message.text)
    os.system("sh find.sh 2>/dev/null")
    bot.send_message(message.chat.id, 'Done')
    return begin(message)
def process_step(message):
    if message.text==u'🔍Start search':
        os.system("cat </dev/null |ssh root@10.14.0.116 killall python 2>/dev/null")
        os.system("cat </dev/null |ssh root@10.14.0.116 python /usr/share/doc/python-fingerprint/examples/example_search.py & 2>/dev/null")
    if message.text==u'👆🏻Add new finger':
            bot.send_message(message.chat.id, 'Place finger on the scaner...')
            output = os.system("ssh root@10.14.0.116 python /usr/share/doc/python-fingerprint/examples/example_enroll.py > add.txt << EOF")
            large_text = open("add.txt", "rb").read()
            splitted_text = util.split_string(large_text, 3000)
            for text in splitted_text:
                   bot.send_message(message.chat.id, text)
                   return name(message)
    if message.text==u'✅Status':
    else:
        bot.send_message(message.chat.id, "Try again")
if __name__ == '__main__':
    while True:
        try:
            bot.polling(none_stop=True)
        except Exception as ex:
            logger.error(ex)
Create additional bash script for name adding to "database"
#!/bin/bash
number=$(sed -n '3p' < add.txt |awk '{print $4}')
if grep -R "New" add.txt
then
sed -i s/$/_$number/ username.txt
sed -n '1p' username.txt >> database.txt
else
    echo not found
fi
Assembling
Relay connection
You can test the relay with python script, just create,paste the code and run it:
#!/usr/bin/env python
import time
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(4, GPIO.OUT)
GPIO.output(4, GPIO.LOW)
time.sleep(1)
GPIO.output(4, GPIO.HIGH)
GPIO.cleanup()
Fingerprint scanner connection
To connect scanner you will need only 4 pins
And that's all, to test it you can run any of python library scripts that you have installed before.
I will post modified Python fingerprint scanner files here, so just download them and overwrite and you are done.
