I finally got around to writing a short guide, both to answer some questions and to make it possible for others to reproduce this project. The current state of the project is barely stable, and many adjustments and options require changing the source code directly. But it is usable and can produce very beautiful results. I hope you enjoy it as I have, and I would love to see what you can come up with.
As time allows I will try to make things more user friendly, and others are welcome to contribute as well.
fhernand
