Repairing a broken display hinge on an Asus Pro31J
I got this old laptop with a broken display hinge. Everything else worked, so I fired up FreeCAD to build a replacement...
bimBim
The display hinge on an old Asus Pro31J I got from a friend was broken, but the rest of the machine worked fine after fixing the display connection with some soldering. I knew we needed a laptop to browse the web in our repair café, so set out on fixing it. After using a Dremel to remove some of the plastic and measuring the broken hinge I fired up FreeCAD and came up with a replacement part which I printed out in ABS for strength. The part fitted almost perfectly and I glued it in with some epoxy. It's not pretty, but it works fine...
Asus_PRO31J_display_hinge.zip
FreeCAD and STL file
Zip Archive - 37.82 kB - 02/07/2018 at 10:26
Download
