A project log for T962A Controller Drop-In (using *PIC32MZ*)
This is a drop-in replacement controller board for the T962A reflow oven, using the PIC32MZEFH as the CPU.
phillyflyersPhillyFlyers 08/02/2019 at 19:090 Comments
Thanks to Keith's comment, never realized you were stuck only being able to edit 'custom profile #1' as there was only ONE custom profile on the original UE firmware update, since the stock board had limited eeprom space.
Fixed the simple bug, now you can edit all 10 custom profiles, and they save, etc.
