Mounting the Setup
A project log for 100$ Xray desktop CT scanner
A computed tomography scanner for your desktop
paul-kocylaPaul Kocyla 07/10/2015 at 17:180 Comments
Mounting of the setup is progressing.
Left upper corner: Plate to which the intensifying screen will be glued
Left lower corner: car ignition coils
Middle low: Rectifying tube
Right lower: Batteries
The camera is protected from the X-Rays by a lead plate
The rotating table is between the screen and the tube
