GitHub Repo Created- All Files Posted!
A project log for Gas Sensor For Emergency Workers
Gas sensor "grenade" that may save lives instead of taking them. The sensor can be thrown into dangerous areas to remotely report levels
eric-wiiliamEric Wiiliam 08/05/2015 at 20:220 Comments
Finally got all the files posted to GitHub for everyone. Hopefully this will make it much easier for anyone else to take this project and make it their own!
In the repository you can find the full Arduino source code, the master Fritzing design file, PCB design files as well as the system design document.
PCB has yet to be tested and is noted in the "issues" section. I should receive the boards from OSHPark in a few days so I can do the final tests. So far the project does exactly what I desired!
Others should now be able to easily reproduce this wherever they may be. Hopefully the GIT repository will make it easier for future modifications and sharing of the project.
Enjoy!
