OpenBionics Origins: Simple Hook Alternatives
A project log for OpenBionics Affordable Prosthetic Hands
Affordable, light-weight, anthropomorphic prosthetic hands, using a novel selectively-lockable differential mechanism.
openbionicsOpenBionics 09/21/2015 at 14:210 Comments
Introduction
The OpenBionics initiative (www.openbionics.org) was founded back in 2013 with the scope of providing open-source, affordable, light-weight robot and prosthetic hands. Our first hands were non-anthropomorphic 2, 3 and 4 fingered robot hands. In this log, inspired by the fact that in every day life tasks most amputees use simple hooks, we present simple, non-anthropomorphic robot hands that can serve as hook alternatives. These hands cost less than 100$ and weigh less than 200 gr.
Bioinspired Robot Fingers
The design is based on the same simple but yet effective idea: to use agonist and antagonist forces to implement flexion and extension of robot fingers, following a bioinspired approach. In this design steady elastomer materials (silicone sheets) are used to implement the human extensor tendons, while cables driven through low-friction tubes implement the human flexor tendons .
The structure of one robot finger is presented. The elastomer materials appear at the lower part of the image (white sheets), while the low-friction tubes (used for tendon routing) appear at the upper part of the image (white tubes) together with the rigid phalanges.
Modular Fingers Basis
Each robot hand has a modular fingers basis equipped with 5 slots that can “accommodate” a total of four fingers. Hands with various geometries of finger base frames, can be developed. Line and 2D polytope geometries are easily created, while for 3D polytope geometries finger bases with different heights have to be used (to create vertical offsets).
Disk Shaped Differential Mechanism
A disk-shaped differential mechanism was developed, in order to connect all the independent finger cables with the single actuator. The differential mechanism allows for independent finger flexions in case that one or multiple fingers have stopped moving, in case e.g., that they are already in contact with the object surface.
For the assembly of the robot fingers we use once again fishing line and needles in order to stitch the silicone sheets onto the rigid links (the links have appropriate holes by design).
Experimental Validation
In this section we present an experimental validation of the proposed simple robot / prosthetic hands. Most of the videos focus on robotics applications that demonstrate the robustness of grasps under object position and orientation uncertainties, but an EMG based control paradigm is also provided.
The first video presents a series of possible applications for the proposed hands. Among them, a three-fingered robot hand is used as a myoelectric prosthesis (by an able-bodied person) and the subject grasps using the myoelectric activations of his forearm muscles, two different objects.
The second video presents autonomous anthropomorphic grasp planning experiments using a four fingered hand. The robot hand efficiently grasps, a series of everyday life objects, even under position uncertainties.
The third video presents a three fingered robot hand mounted on a KUKA YouBot.
The forth video presents the Grebenstein test, where a user hits the robot hand fingers with a hammer in order to prove their robustness again impacts.
Tutorial
A tutorial for the replication of our hands, can be found here!
CAD Files
In this section we provide the cad files (Solidworks .sldasm, .sldprt and .dwg, .dxf, .stl), for the replication of the design.
A new version of our design is under development and can be found in our GitHub repository:
OpenBionics GitHub Repository
