Soldering again at last
A project log for SentriFarm
Solving a key farming problem: is it safe to harvest / spray / sow today? (+experiments with 'big' data in agriculture)
pastcomputepastcompute 08/08/2015 at 14:290 Comments
Things have been a bit slow last week between work and a family member in hospital
Finally assembled the Teensy and Raspberry Pi node version of the SX1276 adaptor shields.
The raspberry pi version is a bit top heavy and will need extra support by the look of it.
This will do for prototyping the software, but I think I'll be designing a much more compact board allowing higher clearance so it mounts the other way over the pi.
Just in case you hadn't guessed, we haven't planned on entering the best product prize category until 2016 :-)
