En-Hump
The goal of this project is to convert loss of vehicle power into electrical energy.
This project somewhat help a city to be smart and this will produce sufficient energy to light-up the street lights. Higher quality sensors would also improve the sensitivity and response of the system. Due to the increased hype around smart machines, humans are doomed to a machine-like future of radically-enhanced lifespan and intelligence. But humans have not get control over the machines on its efficiency and factors.With the En-Hump system, I aim to remove the obstruction provide by speed bumps to replace and instead of power loss of vehicle, get some energy. The project deals with the development of Energy Hump using solenoid and piezo-sensors.The Energy Hump takes the advantage of vehicle weight to produce the charge using solenoid and piezo-pressure sensors.The goal of this project is to light-up the street lights. Hence, the ultimate aim is to develop the energy hump on large scale at low cost. With some future improvements, it may be possible to remove the speed bumps.
  • 1 × Piezo-sensors
  • 2 × Solenoid springs
  • 3 × Battery Evaluation, Demonstration Kits, Boards and Modules / Evaluation Kits, Boards and Modules
  • 4 × Hump Model
