Wifi Captive Portal
A project log for Webmaker tools on Raspberry Pi
Designing a custom Rasbian based SDcard image to run Mozilla Webmaker tools on Raspberry Pi. Aimed for web literacy projects in Africa.
arkyArky 03/20/2015 at 13:350 Comments
Setup hostapd and dhcp. However the ip address are not assigned to clients.
https://learn.adafruit.com/setting-up-a-raspberry-pi-as-a-wifi-access-point/install-software
