This project was something I was given last minute to do as an optional side project at school. I have taken CAD classes before, so this project was not too difficult for me to complete in a reasonable amount of time. I took the broken part I was given and used a caliper to make every single measurement. I did not have a protractor for the angles, so I used the caliper to measure everything until I was able to make the angles work without the protractor. I designed this whole thing in one day and the print took about 3 days (due to the size of the print bed, the orientation of the object caused us to use a lot of support material which in turn extended the length of the print). I talked to the custodian that was trying to replace the part and he said he was unable to find it online and could not think of a way to replace it until he remembered that we have 3D printers at our school.
Kyra S
Alan Chambers
Sam Ettinger
Jaime García
It's impressive to see such initiative in tackling practical problems through student projects, especially with something as technical as ice machine part replacement. Proper maintenance and timely repair can significantly extend the life of such machines, which are crucial in many settings. Speaking of maintenance, for anyone working with ice machines in their projects or businesses, ensuring that these units are clean and functioning efficiently is just as important as fixing or replacing parts. For a comprehensive guide on how to properly maintain and clean your ice maker, check out this resource: https://bftech.pro/how-to-clean-an-ice-maker/ Keeping your equipment in top condition is key to performance and longevity, which complements the innovative work being done on projects like yours.
