Going Small
A project log for Muffsy Phono Preamp PP-2
An Improved AudioKarma CNC Phono Stage
skrodahlskrodahl 03/16/2015 at 12:570 Comments
One of the goals with this project is to make a smaller PCB. In the process, the signal path will be shorter and the board will fit in a smaller enclosure.
I'm starting with this:
And I'm ending up here:
Next I'll talk about the considerations and design choices.
