Etch Your Own PCB
A project log for Muffsy Phono Preamp PP-2
An Improved AudioKarma CNC Phono Stage
skrodahlskrodahl 03/16/2015 at 13:180 Comments
Use this PDF (it's actually two of them, one with the copper layer and one with the silk screen) to etch your own PCB:
http://www.instructables.com/files/orig/FUO/CYCE/I760TVUB/FUOCYCEI760TVUB.zip
The PCB is single-sided, and uses a full ground fill. There's not much copper that needs to be etched away.
