Raspberry Pi: Jabber/XMPP client
Back to overview
This is about using an Instant Messaging client (Pidgin, ChatSecure, etc...) to send and receive messages to/from your Raspberry Pi.
[deleted]
AlfredC wrote 07/22/2016 at 06:10 point
Here it is: https://github.com/FirstCypress/LiV/tree/S_development/software/liv
The code you are interested in resides under livXMPP directory.
It implements a XMPP agent that does this:
http://www.livpi.com/liv-pi-instant-messaging.html
LiV XMPP agent is part of this project:
Here is a brief software architecture description:
http://liv-pi-forum.1124721.n5.nabble.com/LiV-a-brief-software-guide-f67.html
You would need to spend some time to figure out how you can modify the existing code to fit your needs.
Good luck,
Alfred
AlfredC wrote 07/22/2016 at 06:20 point
Just in case this is too complex for your needs, here are a few basic examples: http://xmpppy.sourceforge.net, you can go over them first and then you can decide if you want to take the time to look into livXmpp and modify it.
[deleted]
AlfredC wrote 07/22/2016 at 01:59 point
Try:
sudo apt-get update
sudo apt-get install python-xmpp
This worked for me on Raspbian Jessie.
Best,
-Alfred
