Battery Pack and Programmer Woes
A project log for Circuit Wars
Kill the other Chip! In this Chess-like game of electronics skill, you must disable or destroy the opponent's microcontroller chip.
Les HallLes Hall 03/31/2015 at 05:430 Comments
Above you can see the new battery pack that I 3d printed and the programmer with the broken traces because the adapter board I soldered to it broke off. I think I can fix the programmer with some careful soldering since a header was provided mid-board. Once that is done I'll be ready to perform a test run game of Circuit Wars!
