Connect Different sensors using USB
A project log for NodeUSB- ‘Eat your own dog food’ WiFi IoT DevKit
NodeUSB is a tiny, low cost $9, WiFi ready, ESP8266 USB dev kit for Internet of things, it comes with NodeMCU pre-installed
michael-wenMichael Wen 04/09/2015 at 17:590 Comments
Different connectors
Connect hall sensor:
Connect Relay:
Connect Soil humidity sensor:
Touch Sensor:
ds3231 RTC:
HMC5883L
Light Sensor
OLED display module:
CO sensor
LED module
PIR Sensor
LED light
Ultrasound range sensor
si7021 temperature and humidity sensor
BMP018, BMP085 barometer and temperature sensor
ds18b20
DHT22 sensor
433mHz receiver and transmitter
Use solar battery to power NodeUSB and bmp018 sensor
